In P3D 2012, how do I copy an equipment skid from one project to another?
Solved by w.shafer. Go to Solution.
When you say skid, do you have it as one piece of equipment, or is it a combination of equipment, structure and piping? Or was it an export from Inventor? (.adsk file?)
Tomislav - it is several pieces of equipment connected by piping, all part of a P3D 2012 model.
I may have found my answer. As I right clicked on the new project name, one of the fly-out's was "Add drawing to project", I clicked on that , and then browsed to the file name that I wanted to bring into the new project and it was a done deal.
Fortunately for me, everything in the drawing was what was needed. If only one or two pieces of that drawing were needed, how would I copy only those items into the new project?
Warren Shafer
You shouldn't have one drawing spread across different projects, make a copy of the file in question, then add that copy.
As for being selective, it might be better also to make the equipment a Template, and then use that equipment template for other projects/models.
The drawing in the new project appears to be a copy of the drawing in the old project. Are you saying that if I change the new project drawing, that those changes will be reflected back into the old project drawing?
I was not able to see how to take the several pieces of equipment and the inter-connecting piping and make a single template of all of that.
The equipment has templates, not piping.
If you want to use that as a template for future projects, make one project and call it Template (or something) and then use that project as a template for future projects. Include that model in the Template project?
No problem, you can mark this as "Solved"
