Normally when i select an object in model, i could copy it by rightmouseklick and select copy selection.
Now i'm getting after this selection the message in the command line: select objects.
What happend?
After selecting a block, rightmouseklick, selecting block editor, i'm getting the message in the command line: enter blockname
What happend?
I can't find any solution to fix this problem.
Please advice,
I already checked the "PICKFIRST" command and some settings more.
Nothing helped, so I removed Plant3D from the system and installed it again.
Problem solved.
Thanx for support.
