AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Converting plant 3d from DWG to DGN
4 REPLIES 4
muzu2006
1487 Views, 4 Replies
I have problem when converting the 3d model from dwg to dgn. converted dgn file showes only the pipes and all other fittings , machines , valves and pipe supports are missing.how can I overcome tis problem.
4 REPLIES 4
dave.wolfe
in reply to: muzu2006
You probably have to export to AutoCAD first, and then convert to Microstation.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
muzu2006
in reply to: dave.wolfe
Hi Dave,
Thanks alot for your help, but how do we export to autocad, I am using autocad plant 3d.
can i attach the file if you wish.
Type EXPORTTOAUTOCAD on the command line, in Plant3D
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
nmahale
in reply to: TomislavGolubovic
The Insulation of piping is not coming while I do this command
Please help me on that
”Boost
