I have problem when converting the 3d model from dwg to dgn. converted dgn file showes only the pipes and all other fittings , machines , valves and pipe supports are missing.how can I overcome tis problem.
You probably have to export to AutoCAD first, and then convert to Microstation.
Hi Dave,
Thanks alot for your help, but how do we export to autocad, I am using autocad plant 3d.
can i attach the file if you wish.
@dave.wolfe wrote:You probably have to export to AutoCAD first, and then convert to Microstation.
Type EXPORTTOAUTOCAD on the command line, in Plant3D
The Insulation of piping is not coming while I do this command
Please help me on that
