AutoCAD Plant 3D General DIscussion
Member
muzu2006
Message 1 of 4 (539 Views)
Converting plant 3d from DWG to DGN
539 Views, 3 Replies
10-12-2012 08:44 AM
I have problem when converting the 3d model from dwg to dgn. converted dgn file showes only the pipes and all other fittings , machines , valves and pipe supports are missing.how can I overcome tis problem.
dave.wolfe
Message 2 of 4 (496 Views)
Re: Converting plant 3d from DWG to DGN
10-14-2012 01:59 PM in reply to: muzu2006
You probably have to export to AutoCAD first, and then convert to Microstation.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Member
muzu2006
Message 3 of 4 (491 Views)
10-14-2012 02:11 PM in reply to: dave.wolfe
Hi Dave,
Thanks alot for your help, but how do we export to autocad, I am using autocad plant 3d.
can i attach the file if you wish.
Employee
TomislavGolubovic
Message 4 of 4 (485 Views)
10-14-2012 04:12 PM in reply to: muzu2006
Type EXPORTTOAUTOCAD on the command line, in Plant3D
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
