AutoCAD Plant 3D Forum
Converting Cadworx2013 Specs To Plant 3D
11 REPLIES 11
Message 1 of 12
Ahmed1081975
1452 Views, 11 Replies
Hi Autodesk Supports,
The New Release Form CadWorx2013R2 it can be now converting the specs from AutoCAD Plant 3D to CawdWorx
Specs. And from the other way the AutoCAD Plant 3D up till now can't convert the Cadworx2013 Specs to Plant 3D
Specs, there no update for AutoCAD plant 3D for these issue
Ahmed Helal
11 REPLIES 11
Message 2 of 12
Hi Ahmed,
Select 'File - Convert - CadWorx Spec' from the menu in the spec editor (see attached snapshot). A dialog box will open and you have to select your CADWorx spec file (*.spc), your standard library with referenced files, your datafile.tbl and the target folder for the converted specs.
Please, inform me if I could help you
Regards
Bernd
Bernd G.
Senior Product Support Specialist
Message 3 of 12
Hi Bernd,
Thanks for Your Reply, I think you didn't get my point, my issue converting Specs from CadWorx2013 Version in the
previous version no problem but with new version Plant 3D can't read even the extension file ( .prj) Befor Was spec
file Extension in CadWork  (.spc)
I hope my issue be clear now
Ahmed Helal
Message 4 of 12
Hi Ahmed,
Thank you for clearing here the point. Yes, this is currently not possible. I will ask internally if there is already an update for the version 2014 here or if there are additionally plans for 2013.
Regards
Bernd
Bernd G.
Message 5 of 12
Hi Ahmed,
I've got now the answer of the development here. They were not aware of this change in the new CadWorx 13R2 release. I have logged now this issue to them and they will work for this topic here.
Regards
Bernd
Bernd G.
Message 6 of 12
Thanks, for the interesting
Ahmed Helal
Message 7 of 12
Bjschw44
in reply to: Ahmed1081975
Has Autodesk adressed this issue? It has been a year on this forum and no answer what's the solution?
Message 8 of 12
Bjschw44
in reply to: Bjschw44
Is anyone looking into this on the Plant 3D side. This is a big issue and Autodesk always touts their user groups and forums for support and this issue is a year old with no one from Autodesk having a response. This sounds a lot like Bentley....the reason we are leaving Bentley.
Message 9 of 12
dgorsman
As you note, the best use of this forum is to leverage the experience of other users.  This isn't the best (or proper) location to log feature requests or get direct AutoDesk support.  Unless there is a *lot* of demand for this then it probably won't be added to the product while there are higher priorities.
If there is enough demand to make it worth their while a third-party solution might be an option.
Message 10 of 12
Bjschw44
in reply to: dgorsman
I guess there is enough demand since the option to convert the files exist for previous versions of Cadworx.
Message 11 of 12
It's now 2019, and there is still no support for .prj files.  This is disappointing for engineering companies because the cost of spec creation is not something they take on as an overhead cost, it usually gets billed to clients, but everyone already has CADWorx libraries... I don't mean to rant, but this is a missed opportunity for market cap.
Message 12 of 12
Anything new on this?
We have a suite that has Plant 3D and we aren't going to use it if we can't convert our already correct specs from Cadworx to Autocad.
”Boost
