AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Converted spec elbows have incorrect dimensions
2 REPLIES 2
twdtech
581 Views, 2 Replies
I have converted an Autoplant spec to Plant3D. The conversion was 100% according to the conversion routine. However, I have discovered that the long radius elbows are being drawn with a radius of 1.5 times the outside diameter of the pipe instead of 1.5 times the nominal diameter. How can I fix this problem?
2 REPLIES 2
richard
in reply to: twdtech
You can change this in AutoPLANT to Plant 3D Mapping settings by:
1. File->convert->settings->AutoPLANT settings
2. Pick Geometry Mapping
3. Class AT_ELBOW_LR_90
4. Change the Parameter Mapping R from 1.5*PIPE_OD_M to CTR_END_M
Best Regards,
Richard Strikker
CADTEAM the Netherlands
twdtech
in reply to: richard
Hi Richard,
Thanks for your help with this problem. I am surprised that the Autodesk would issue their software with a default mapping that is incorrect. I have now lost confidence in the spec converter as I do not have time to check every component mapping from Autoplant to Plant3D.
”Boost
