AutoCAD Plant 3D Forum
Converted Autoplant Specs flange connection problem
2 REPLIES 2
maxdc
367 Views, 2 Replies
I converted an autoplant specs into plant 3d. the stud bolts didn't convert so I inserted them from the ASME catalog.
When I try to connect flanges, I cant. and the following messege appears.
I do not have any problems when connecting flanges from specs created in P3D
How can I solve this?
2 REPLIES 2
PeterQuinn
in reply to: maxdc
Looks like the nominal is listed as "2in" rather than "2". This will need to match.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
maxdc
in reply to: PeterQuinn
Peter, Thank you.
I tried to change that, but i found that it was easier to change the whole part from the asme catalog.
”Boost
