I have converted some Autocad 3d drawing into Autocad Plant 3D equipment model as per procedure attached herewith (help file of Plant 3D).
However
Nozzle has been added as per the procedure but it is not appearing in the model; only a point and pencil can be seen.
please help me to resolve the problem.
Solved by Peter_Jansoone. Go to Solution.
nozzle graphics are not added to converted equipment, only to native parametric equipment. When you convert equipment, it's assumed that the nozzles are already there. The PLANTPARTCONVERT command just identifiees the port location and properties.
The above post made by Peter is correct.
The nozzles you add will be on the equipment but a graphical representation is not automatically created. You will need to add that to the solid before it is converted.
Dan
