Is there a way to have Plant 3D recognize that I want to number the weld counts sequentially throughout all of my ISO drawings instead of it starting back over at 1 on each ISO?
In IsoConfig.xml in the section AggregatedList file find "ShopWelds" or "FieldWelds" and modify: ContinuousIndexing="true"
This works only for 50%.
The continuation of the weld numbers work except on the second sheet they start form the wrong end.
So if you have 1-5 on the first sheet and 6-10 on the second then on the second sheet, where it's connected to the first sheet, it starts form 10 instead of 6.
Any idea on how to fix that?
Unfortunately not within Plant 3D self.
We purchased a plugin which does te job perfectly.
https://apps.autodesk.com/PLNT3D/en/Detail/Index?id=7524156163626155052&appLang=en&os=Win64
