AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Concentric, Eccentric Reducers and Reducing Tees
7 REPLIES 7
Message 1 of 8
asalcido
3939 Views, 7 Replies
How do you input the data in the spec Editor 2012 to show the difference in schedule of pipe fittings.  For example, a concentric reducer 4" SCH 80 LE x SCH STD SE.
Alex Salcido
Tags (2)
7 REPLIES 7
Message 2 of 8
asalcido
in reply to: asalcido
So does anyone have anything about this?
Message 3 of 8
jason.drew
Typically you would use the "Batch Assign Long Description Styles" function of Spec Editor to configure a new format or string for the properties you would need.
I attempted to configure the long description as you mentioned above. However, I wasn't able to use the size field for the second part of the string.
I am assuming you would want something similar to this for a reducer that changes in size and schedule (as an example):
4" SCH 80 LE x 6" SCH STD SE
Would be something like:
<Nominal Diameter>" SCH <Schedule> LE x <Nominal Diameter>" SCH <Schedule> SE
So there are two property fields for size and schedule in the spec, but the long description style editor only recognized the first entry for size and schedule.
The workaround I tried was to create 4 new fields:
SIZE1
SIZE2
SCH1
SCH2
But unfortunately you cannot use custom property fields in the long descriptions.
I have submitted this issue to the development team.
Thank you,
Jason Drew
Designated Support Specialist
Message 4 of 8
asalcido
in reply to: jason.drew
Thanks Jason.  Just wanted to make sure I wasn't missing something.
Message 5 of 8
dry
Does this issue been solved in PLANT 3D 2014?
So far I cannot find how to describe (using long description style manager) two-dimensional fittings such reducer or reducing tree. On iso drawing BOM there will be always first (larger) dimension parameters visible (i.e. wall thickness). It is very confusing.
Regards
Dominik Ryś
Message 6 of 8
PeterQuinn
in reply to: dry
Does this utility from ECAD solve the problem:
http://apps.exchange.autodesk.com/PLNT3D/en/Detail/Index?id=appstore.exchange.autodesk.com%3apdoexte...
Peter Quinn
Senior Product Manager
Message 7 of 8
thienthanh81
in reply to: dry
Dear all,
How about this problem, Does it fix with Plant 3D 2018?
Thank,
Message 8 of 8
I just went through the issue of calling out schedules for tee branches and reducers.  I posted my solution here:
https://forums.autodesk.com/t5/autocad-plant-3d-forum/schedule-of-tee-branches-and-reducers/td-p/881...
I used the strategy of assigning custom properties as described earlier in this thread.  To get the long description styles to pull the custom properties I used an xml editor.
”Boost
