We just upgraded to Plant 3D 2014 and I am having a problem creating ortho views containing structural columns with base plates. The columns and steel base plates are sitting on top of concrete foundations. When I create an ortho plan view of the columns, the base plates are drawn offset down and to the right of the columns. The columns and foundations are drawn in the correct locations. I have checked the model and the base plates are in the correct location. I did not have this problem in Plant 3D 2013 but found this problem when I migrated the project to 2014. I created a brand new model in a new project to see if the migration was the problem. I had the same result.
Has anyone else run into the same problem? Is there a fix for it?
Tony
I believe if you install Extension 1, it will fix this problem. I see that Ext.2 is out now, but I have not installed this version.
