AutoCAD Plant 3D General DIscussion
Valued Mentor
JohnHolder
Message 1 of 9 (818 Views)
Colour Coding Pipes
818 Views, 8 Replies
12-07-2012 02:29 PM
This has been in the back of my mind for a while now.
Inside <Project Setup> <Plant 3D DWG Settings> <Layer and Color Settings>
I have the <Piping settings> to assign colour according to the service
RS ( recirc supply ) is blue
RR ( recirc return ) is green
etc.
I also use alot of custom blocks since the sch 40 library is lacking.
Native pipe fittings always change colour but the custom fittings always remain white.
is there a setting that I can change?  or what is going on.  It's not a huge issue, the drawing
sets are done in B&W but for 3d DWF's clients like the coloured pipes because it helps them
understand the water flow much easier and it's a wee bit annoying having a bunch of white fittings
inbetween nicely coloured pipes.
any suggestions?
and enjoy your weekend people!
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
You should set it to ByBlock before you created the part. After that, you can edit the block definition in the drawing that contains the part, or in any of the models it is used in (for existing components).
dgorsman
Message 2 of 9 (812 Views)
Re: Colour Coding Pipes
12-07-2012 03:28 PM in reply to: JohnHolder
Custom content color BYLAYER or BYBLOCK?  Or hard-coded color?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
dave.wolfe
Message 3 of 9 (807 Views)
12-07-2012 09:48 PM in reply to: JohnHolder
You have to set the objects color to byblock
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Valued Mentor
JohnHolder
Message 4 of 9 (745 Views)
12-10-2012 09:12 AM in reply to: dave.wolfe
Ok, in the active drawing, changing the parts to <byblock> did nothing
I selected one fitting - changed it to <byblock> then went into the <Data Manager> and changed the service group to force a line colour change - nothing.  Then went into <Bedit> to check that fitting which was already <byblock>
also doing the same as above to bylayer of course did nothing.
I also noticed if I select the part, it is a service <RR> line, the colour is blue.  I change it to <byblock>
force the line colour change in the <Data Manager> it reverts back to the colour and not <byblock>
So where do I need to be changing it?  Do I have to go back to the original file where I created the blocks change it there then update each block in the spec editor? - asking first before attempting this since it is a large job.... 8(
John.
Master Yoda.
dave.wolfe
Message 5 of 9 (732 Views)
12-10-2012 05:03 PM in reply to: JohnHolder
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
PatrickByrne
Message 6 of 9 (722 Views)
12-10-2012 07:40 PM in reply to: dave.wolfe
It also depends on what your Layer and Color Settings are.
I have mine set up to Assign layer by Spec and Assign color by Layer. This helps later on if I want to change the color of the model in the xref assembly.
I have also put a request in the 2014 wish list so that you could set up the layer color in the project properties.
PatrickByrne
Message 7 of 9 (721 Views)
12-10-2012 07:41 PM in reply to: PatrickByrne
To add to the above, my custom blocks are then set to Bylayer
dave.wolfe
Message 8 of 9 (694 Views)
12-11-2012 09:05 AM in reply to: PatrickByrne
If you want the block to assume the layer and color automatically from the settings, you should set it to by block before creating the custom part.
http://docs.autodesk.com/PLNT3D/2013/ENU/filesPCR/GUID-E40E4CF9-B900-4599-A987-641F1FFF33C2.htm
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Valued Mentor
JohnHolder
Message 9 of 9 (692 Views)
12-11-2012 09:06 AM in reply to: dave.wolfe
Ok got it working.  When I was testing it, what happened was the True union ball valve was a block in a block - I did not notice it right away.  when I exploded the inner block then set it to <by block> it worked.  takes a few minutes per drawing... but looks like I will have to have a look at my spec again and correct this so it doesn't happen again.
Master Yoda.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
