AutoCAD Plant 3D General DIscussion
Member
JVNows
Message 1 of 3 (302 Views)
Color overrides 'material' from some piping elements, only in assembly.
302 Views, 2 Replies
05-26-2011 07:47 AM
Hi all,
I have a drawing with piping, I've given all the parts a material and tested it in the wame drawing with a render, giving perfect results, how I'd expect it.
If I Xref (or even import as a block) this piping drawing into our assembly, certain piping elements (bends, T's, ...) get the color of their layer, not the material I've given them.
Thanks in advance!
screenshots attached
Valued Contributor
bogdanov.y
Message 2 of 3 (236 Views)
Re: Color overrides 'material' from some piping elements, only in assembly.
06-02-2011 11:02 AM in reply to: JVNows
I don't know why the program do this in Navisworks current the same.
 One question how do you do the circular railing?
Active Member
Mudbay
Message 3 of 3 (117 Views)
09-12-2012 04:22 AM in reply to: JVNows
Hi, I got the same problem. Every pipe part that is straight, the steel material is shown correct when rendering, but all Tees, bends and so on still got the gound color even though the properties say it's got the steel texture.
/Mattias
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
