AutoCAD Plant 3D Forum
Color overrides 'material' from some piping elements, only in assembly.
2 REPLIES 2
JVNDRANCO
475 Views, 2 Replies
Hi all,
I have a drawing with piping, I've given all the parts a material and tested it in the wame drawing with a render, giving perfect results, how I'd expect it.
If I Xref (or even import as a block) this piping drawing into our assembly, certain piping elements (bends, T's, ...) get the color of their layer, not the material I've given them.
Thanks in advance!
screenshots attached
2 REPLIES 2
bogdanov.y
in reply to: JVNDRANCO
I don't know why the program do this in Navisworks current the same.
 One question how do you do the circular railing?
Mudbay
Hi, I got the same problem. Every pipe part that is straight, the steel material is shown correct when rendering, but all Tees, bends and so on still got the gound color even though the properties say it's got the steel texture.
/Mattias
”Boost
