AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Color of hidden lines in Ortho 2014
6 REPLIES 6
snijdam
937 Views, 6 Replies
When I create an ortho which contains hidden parts, plant 3D shows the line in a dashed line. That is fine. I changes the color of the line to standard white. And not the original color of the part. Is it possible to change this behavior?
6 REPLIES 6
Attila.Vallyon
in reply to: snijdam
Go to project setup
Ortho DWG Settings/Title Block and Display
Setup Title Block
Ortho Settings
there you can assign layer fo thr Hidden Lines
Attila Vallyon
snijdam
in reply to: Attila.Vallyon
that is not the solution I was looking for
The solution is similary to the last post of you: http://forums.autodesk.com/t5/AutoCAD-Plant-3D/non-consistent-color-use-in-Ortho-generation/m-p/4447.... Open the layer management in the template and select the color for the hidden lines which you prefer.
Regards
Bernd
Bernd G.
Senior Product Support Specialist
I don't want to assign a specific color to the hidden lies layer. I want the hidden lines to have the same color as the 3D part.
Did you find the solution ? I have the same problem ;/
eepesa
Find your solution??
”Boost
