AutoCAD Plant 3D General DIscussion
Valued Contributor
Martin60
Message 1 of 3 (247 Views)
Collars
247 Views, 2 Replies
03-16-2010 10:00 PM
I am currently learning and setting up 3D Plant.
I require collars on the end of my pipes for rotating flanges.
There are collars available in the catalogs DIN Pipes and Fittings Catalog.pcat and CustomParts Metric Catalog.pcat but I cannot see how to add these objects.
I noticed that when in the spec viewer the option to add collars to the palette is disabled.
Can someone explain the correct use of these objects and how I can achieve the collars I require.
*Jorge Lopez
Message 2 of 3 (247 Views)
Re: Collars
03-17-2010 08:46 AM in reply to: Martin60
Hi Martin,
Collars are fasteners and as such cannot be placed manually. They are
automatically added to form the connection when needed and reside within a
connector entity (as a sub-entity).
There is a single joint definition named CollarLapped that adds a Collar and
a Buttweld when connecting a LAP end condition to either a BV or PL end
condition. It is superceded by StubLapped that is used in the same situation
but is found first. In Project Setup, Joint Settings, you can remove
StubLapped or change it so it is not picked up.
You can also change the situation when a Collar is used by either changing
the joint definition or creating a new one.
Hope this helps.
Jorge Lopez
"Martin60" wrote in message news:6355898@discussion.autodesk.com...
these objects.
Valued Contributor
Martin60
Message 3 of 3 (247 Views)
Re: Collars
03-17-2010 02:18 PM in reply to: Martin60
Thanks Jorge
Sounds good.
Will let you know if I have any problems.
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
