Hi,all.
I have an issue about how to choose a suitable bolt automatic when inserting a valve.
In the spec,I have added a Single-head bolt and a stud bolt.I'm not very sure that how to call them in English.No matter what,there are two different kinds of bolt.When I insert a globe vavle in plant 3d 2012,I want the program use a Single-head bolt set,and a stud bolt when wafer butterfly valve.But the reality is, no matter what kind of valve I inserted,the program would use a single-head bolt set.
Anyone can help me?
Thanks.
Bin.
Solved by lyowbeen. Go to Solution.
I know this is a 2 year old thread.
I have trouble get the bolt length to work correctly for wafer connection.
Thanks in advance
Can you explain more please? I'm trying to do what you're doing but I can't seem to get the bolt sets to play nice. It usually defaults to one bolt set or another.
