Can you write 1 of your description? We also have very long description, just want to see how many characters your description have. thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Are you using Long description Size?
Best Regards,
Pat Andres
GHD Manila
I've also checked the catalog, and maybe this is the limit that i could get.
Best Regards,
Pat Andres
GHD Manila
I tried to create a custom property in catalog via 2014 version and the max character it accepts is only 255.
Best Regards,
Pat Andres
GHD Manila
I'll check on this. Most of our guys are out on break, but I'll see what I can find out.
No. I checked and it's not possible to have longer fields.
Could you add a second description field (Description2 or something) and split up the text? It could be concatenated in reports. Annoying, I know.
Hi everyone!!! Any progress on this issue??
I am facing the same problem with our client descriptions.
Plant 3D 2024
I believe it is a windows limitation not a software limitation. You can test this by changing the character limit on your windows machine.
https://answers.microsoft.com/en-us/windows/forum/all/enabling-long-path-to-allow-files-with-long-na...
Hello
If we look at the SQLite databases of specification files and catalog files we can see that the size of the "PartFamilyLongDesc" and "PartSizeLongDesk" properties are declared on 255 characters. With the "SQLite Expert Pro" application (for example ) we can change this value to 512 characters.
In the "Piping.dcf" file we find these same properties at a size of 255 characters. We can change this value to 512 characters but in the object property, in the data manager, in the ortho nomenclature and in the iso nomenclature, this size remains blocked at 255 characters!!!
I think this maximum size of 255 characters is fixed in the Plant 3D application.
== French ==
Si on regarde les bases de données SQLite des fichiers spécifications et des fichiers catalogues on peut s"apercevoir que la taille des propriétés "PartFamilyLongDesc" et "PartSizeLongDesk" sont déclarées sur 255 caractères. Avec l'application "SQLite Expert Pro" (par exemple) on peut changer cette valeur pour la passer à 512 caractères.
Dans le fichier "Piping.dcf" on retrouve ces mêmes propriétés à la taille de 255 caractères. On peut changer cette valeur en 512 caractères mais dans la propriété de l'objet, dans le gestionnaire de données, dans la nomenclature ortho et dans la nomenclature iso, cette taille reste bloquée à 255 caractères !!!
Je pense que cette taille maxi de 255 caractères est fixée en dur dans l'application Plant 3D.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
yes, absolutely
I did try it by changing directly on the piping.dcf, the varchar size.
I didn't work. I also openned a case , still waiting their answer
