AutoCAD Plant 3D General DIscussion
Valued Mentor
JohnHolder
Message 1 of 2 (127 Views)
Changing the insertion point of an ortho view? ( create ortho view )
127 Views, 1 Replies
01-29-2013 11:05 AM
Is there a command to change the insertion point of an ortho?
currently it defaults to the bottom left corner, I want to change it to the center.
I place the ortho down then select the mid between two points to replace each and every ortho I place, which is a lot of wasted time.
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
HI,
It is not possible to change the default insertion point of the ortho viewport from the bottom left point.
You can post a feature enhancement request here:
Product Feedback
Dan
Product Support
Dan.Scales
Message 2 of 2 (89 Views)
Re: Changing the insertion point of an ortho view? ( create ortho view )
02-01-2013 04:11 AM in reply to: JohnHolder
HI,
Product Feedback
Dan
Dan Scales
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
