Is there a command to change the insertion point of an ortho?
currently it defaults to the bottom left corner, I want to change it to the center.
I place the ortho down then select the mid between two points to replace each and every ortho I place, which is a lot of wasted time.
John.
Solved by Dan.Scales. Go to Solution.
HI,
It is not possible to change the default insertion point of the ortho viewport from the bottom left point.
You can post a feature enhancement request here:
Dan
