AutoCAD Plant 3D General DIscussion
Valued Contributor
19820415
Message 1 of 2 (199 Views)
change the default dimention value for custom part in 2013
199 Views, 1 Replies
06-19-2012 02:45 AM
Hi all
is there anyway to change the default dimention value for those custom parts?
then we can use it dirrrectly and do not have to change it every time.
thanks.
Product Support
Dan.Scales
Message 2 of 2 (152 Views)
Re: change the default dimention value for custom part in 2013
07-05-2012 07:56 AM in reply to: 19820415
You need to edit the “CustomParts Imperial Catalog.pcat” and/or “CustomParts Metric Catalog.pcat” that are located in the folder "C:\AutoCAD Plant 3D 2013 Content\CPak Common".
Once you have done that you need to update the specs that are stored here (CustomParts Imperial.pspx and/or CustomParts Metric.pspx):
C:\AutoCAD Plant 3D 2013 Content\CPak Common\CustomPartsSpecs.
I hope this helps.
Dan
Dan Scales
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
