AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
change the default dimention value for custom part in 2013
1 REPLY 1
400 Views, 1 Reply
Hi all
is there anyway to change the default dimention value for those custom parts?
then we can use it dirrrectly and do not have to change it every time.
thanks.
1 REPLY 1
Dan.Scales
in reply to: 19820415
You need to edit the “CustomParts Imperial Catalog.pcat” and/or “CustomParts Metric Catalog.pcat” that are located in the folder "C:\AutoCAD Plant 3D 2013 Content\CPak Common".
Once you have done that you need to update the specs that are stored here (CustomParts Imperial.pspx and/or CustomParts Metric.pspx😞
C:\AutoCAD Plant 3D 2013 Content\CPak Common\CustomPartsSpecs.
I hope this helps.
Dan
Dan Scales
”Boost
