Hello, my question is if it's posible to change the service in 3D pipe? Because service and the line number are propertie of Pipe Group, and in the Data Manager there aren't this category. Is posible to access to List of Pipe Group to modify? (in the project without SQL server).
go to project properties, under Data Manager Configuration, change the view type to by Area. Then you should see the linegroup data in the data manager when you select the Pipe Lines.
