AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Change pipe sizes or Specs
6 REPLIES 6
jvelezt
4784 Views, 6 Replies
Hello All
How in Plant 3d I will change the size or spec to an big route with many accesories in line created  ?
Have Plant 3d any comand to made this?
Simmilar to Changesize or changespec of CadWorx?
Juan
6 REPLIES 6
patpat79
in reply to: jvelezt
Hi, if the change size/spec issue you are saying is, there is an existing modeled pipe line that needs to be editted in size/spec, yes you can. Just select your whole pipe line by either by "selection window",or by "selecting a single component, use right mouse button, select add to selection function, use "entire line number/ all connected parts". After your whole pipe line routing/model is selected, open your properties tab, select the Size or Spec field, then change it to what size or spec you want and it will change your whole routing to that size or spec. But, please be aware that, if you do not have the same component or fittings on the size that you will be replacing, or you dont have the same components property on the spec that you will substitute to your existing model (eg. pressure class of flanges/valves, end types, etc.) your line will be disconnected and will require reconstruction and or checking. But then, if they have, it will be changed and will have no problem at all. Thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
jvelezt
in reply to: patpat79
Thanks patpat79 for your fast solution
patpat79
Hi, very pleased to help. Thanks
Best Regards,
Pat Andres
GHD Manila
paragnewe
we need to take some more precaution while changing SIze / spec for entire pipe : -
 1. charging of line size may change your BOP / TOP of piping which might be create mess to re-route and setting of BOP.
 2. while selecting by option " select add to selection function, use "entire line number/ all connected parts"" , you might select connected other line number (which you dont want to change ) and that line also may  change in size / spec. (I face this problem and now doing rework 😞 Smiley Embarassed)
so we need to keep eyes open while resizing of lines.
-Regards
Prag
jvelezt
in reply to: paragnewe
Yes In Cadworx 2014 an alert is showing when the change is made.
patpat79
In case of unwanted changes like parag had encountered, you can always use undo command so you could do the spec/size change perfectly, but always with precautions. Thanks
Best Regards,
Pat Andres
GHD Manila
”Boost
