Hi Autodesk Support,
How Can I change the Pipe size in one time, For Example I have the pipe
line inside the cloud DN400 I want to change to DN250 at once, for more
clarification Refer the attached file.
Ahmed Helal
Hi Ahmed,
You just need to select the pipes shown and then change the size in the Properties Palette.
Dan
Dear Dan,
Thanks for Your reply, I did this already Dan but see in the attached files what is happened
Ahmed Helal
Hi Ahmed,
You need to make sure that the parts are available in the spec that are needed to make the pipe line connect OK.
Check that the parts required are available.
Dan
Hi dan,
All parts & size are avalible in my Spec File
Ahmed Helal
Hi Ahmed,
The pipe line is too complex to change the size in one go.
You will need to edit it in sections.
Dan
