AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Change dimensions of reinforcing pad
2 REPLIES 2
panchozu
1143 Views, 2 Replies
how I can change the dimensions of reinforcing pad?.... the instructions do not work: http://docs.autodesk.com/PLNT3D/2013/ENU/index.html?query=reinforcement%20pad
2 REPLIES 2
Press CTRL and then the pad, then you can change the properties.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Thanks!!!
”Boost
