AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Centrifugal Pump Issue
3 REPLIES 3
Ahmed1081975
711 Views, 3 Replies
Dear All,
I have Pump the discharge not same center line of the suction how I will get
For more clarification refer to the attached files
Ahmed Helal
3 REPLIES 3
Hi Ahmed,
I understand that you have a model of a pump and you want to use it as a Plant 3D equipment. Do you have the new user-defined pump as an AutoCAD model or as Inventor assembly? Depending on that you will use command PLANTEQUIPMENTCONVERT (AutoCAD model) or PLANTINVENTOREQUIPMENTCONVERT (Inventor) to convert this model to a Plant 3D equipment.
Regards
Bernd
Bernd G.
Senior Product Support Specialist
Thanks for your reply
Actually those two issues I know about it my point is should be including the programs because I have for each model draw first in 3d model and converting witch is cost me a big time I was hope the another easy  solution.
Ahmed Helal
Hi Ahmed,
Currently we don't have here a big library here for equipments. And PLANTEQUIPMENTCREATE creates more general equipments, not such specific as you want. So I'm sorry to say that you have to use either PLANTEQUIPMENTCONVERT for AutoCAD models or PLANTINVENTOREQUIPMENTCONVERT for Inventor assemblies.
Regards
Bernd
Bernd G.
”Boost
