AutoCAD Plant 3D General DIscussion
Ahmed1081975
Message 1 of 4 (393 Views)
Centrifugal Pump Issue
393 Views, 3 Replies
12-10-2012 10:21 AM
Dear All,
I have Pump the discharge not same center line of the suction how I will get
For more clarification refer to the attached files
Ahmed Helal
Product Support
gersteb
Message 2 of 4 (328 Views)
Re: Centrifugal Pump Issue
12-12-2012 05:40 AM in reply to: Ahmed1081975
Hi Ahmed,
I understand that you have a model of a pump and you want to use it as a Plant 3D equipment. Do you have the new user-defined pump as an AutoCAD model or as Inventor assembly? Depending on that you will use command PLANTEQUIPMENTCONVERT (AutoCAD model) or PLANTINVENTOREQUIPMENTCONVERT (Inventor) to convert this model to a Plant 3D equipment.
Regards
Bernd
Bernd Gerstenberger
Ahmed1081975
Message 3 of 4 (298 Views)
12-15-2012 12:02 AM in reply to: gersteb
Thanks for your reply
Actually those two issues I know about it my point is should be including the programs because I have for each model draw first in 3d model and converting witch is cost me a big time I was hope the another easy  solution.
Ahmed Helal
Product Support
gersteb
Message 4 of 4 (264 Views)
12-17-2012 03:05 AM in reply to: Ahmed1081975
Hi Ahmed,
Currently we don't have here a big library here for equipments. And PLANTEQUIPMENTCREATE creates more general equipments, not such specific as you want. So I'm sorry to say that you have to use either PLANTEQUIPMENTCONVERT for AutoCAD models or PLANTINVENTOREQUIPMENTCONVERT for Inventor assemblies.
Regards
Bernd
Bernd Gerstenberger
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
