AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Centreline display of structural member in ortho view
7 REPLIES 7
Message 1 of 8
Arun_Kumar_K
573 Views, 7 Replies
The centre line for structural members are not displaying in ortho view, which is required for annoting the dimensions, and for better appearance.
7 REPLIES 7
Message 2 of 8
TRdesigner82
in reply to: Arun_Kumar_K
Did you ever come up with a solution to this?
Message 3 of 8
Arun_Kumar_K
in reply to: TRdesigner82
No solution yet.
Message 4 of 8
TRdesigner82
What's your workaround then to ensure that you're attaching to the center of a column?
Message 5 of 8
patpat79
Grid lines?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Message 6 of 8
PPlenevaux
in reply to: patpat79
You can use the MTP snap, select two external points on the profile, and then you'll get the axis of the structure member.
Pascal
PRAYON sa
Message 7 of 8
Arun_Kumar_K
in reply to: PPlenevaux
M2P can be used for finding centreline, the wishlist was auto generation of centreline display display similar to pipeline for structual members too.
Message 8 of 8
This would be most helpful to convert skid frames over to Inventor for detail modeling. Rather than the go around to another autodesk software which generates the lines with more process involvement. This also means more room for errors to be generated.
”Boost
