Ok, another release, and another headache.
I really really do not want to rebuild the 3 catalogs from scratch yet again.
how do you migrate custom blocks from 2013 to 2014. i have specified the location to them during 'migration' and of course nothing works.
Most of it is parametric modeling - sch 40 sch 80 and HDPE standard, and HDPE metric.
but too many parts are missing and I had to model them myself.
Solved by dave.wolfe. Go to Solution.
So, loading up 2013 spec editor and exporting to excel, then building a catalog in 2014 seemed to work ok.
except for alot of the images are missing in the tool pallet, but that is not a big issue.
annoying that the migration fuction fails..
For the parts that I created in 2013, images/source files were located in C:\AutoCAD Plant 3D 2013 Content\CatalogSupportFolders
Under there should be a folder per catalog that has block based parts.
I was able to copy that catalog folder to the 2014 and all of the source pathing issues were resolved.
For example, "C:\AutoCAD Plant 3D 2013 Content\CatalogSupportFolders\ECAD Houston" got copied to:
"C:\AutoCAD Plant 3D 2014 Content\CatalogSupportFolders\ECAD Houston"
I don't know why the migrate feature doesn't include this, but I'm submitting a bug ticket for it.
Some catalogs are in the
others are inside
C:\AutoCAD Plant 3D 2013 Content\CPak Common
that may have been part of the problem?
right now the catalogs work, but are just missing images on the tool pallet. I renamed the catalogs
when I rebuilt them, just in case I tried the migration again. Which I will and I will attempt to copy over the supporting
documents
Edit
Thank you again Dave. That was the issue, the supports folder was not in the right place, I should have looked around more to find it! But migration worked properly.
Partial success. Standard catalogs, both sch 40 and hdpe work fine!
Metric catalogs, both PVCu and HDPE do not - lots of parts missing..
working on that now.
