AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Catalog load
1 REPLY 1
sannese
424 Views, 1 Reply
Catalog load
When i open up Plant 3d 2015 an error occurs:
Unable to load catalog file
'C:\Users\sannese\AppData\Roaming\Autodesk|AutoCAD Plant 3D 2015\R20.0\enu\support\ToolPallette\AcPpAssetToolCatalog.atc'
This occured after a software crash.  Also when i try to open my project drawing it is coming up with a critical error.
Can someone please help me with the catalog load at least.  I am thinking once that is fixed my other issues will go away.
1 REPLY 1
dennis
in reply to: sannese
Not sure if this will help, but try going into the project folder and delete the file: SubstitutionPalettes.xml
When next you access the project, P3D will rebuild this file.
”Boost
