AutoCAD Plant 3D General DIscussion
Active Member
jessica
Message 1 of 3 (170 Views)
Catalog Editor
170 Views, 2 Replies
10-05-2011 06:53 AM
I am trying to create a cast iron spec, and currently ther eis no spec for anything 15" so, everytime i try to create a spec, either from new or duplicating, spec editor says it has stopped working and closes.  This has happened 4 times this morning.  Can anyone verify this problem for me?
Active Member
jessica
Message 2 of 3 (165 Views)
Re: Catalog Editor
10-05-2011 07:48 AM in reply to: jessica
so i was able ,to create it, appenrtly it does not like when you type in " (inch), but now im having a problem finding a block to put in as a picture, why doesnt it automaticlally use the existing for the other pipe sizes?
Product Support
jason.drew
Message 3 of 3 (122 Views)
Re: Catalog Editor
10-11-2011 10:07 AM in reply to: jessica
Hi Jessica,
You mentioned you're having a problem finding a block to put in as the picture, are you referring to the preview image for the part (dimension sheet)?
Thank you,
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
