AutoCAD Plant 3D Forum
Catalog Editor
2 REPLIES 2
jessica
347 Views, 2 Replies
Catalog Editor
I am trying to create a cast iron spec, and currently ther eis no spec for anything 15" so, everytime i try to create a spec, either from new or duplicating, spec editor says it has stopped working and closes.  This has happened 4 times this morning.  Can anyone verify this problem for me?
2 REPLIES 2
jessica
in reply to: jessica
so i was able ,to create it, appenrtly it does not like when you type in " (inch), but now im having a problem finding a block to put in as a picture, why doesnt it automaticlally use the existing for the other pipe sizes?
jason.drew
Hi Jessica,
You mentioned you're having a problem finding a block to put in as the picture, are you referring to the preview image for the part (dimension sheet)?
Thank you,
Jason Drew
Designated Support Specialist
”Boost
