Hi there.
In Plant 3D spec editor 2015, I am trying to create a new catalog. If one navigates into Show Advanced Editing Table in Sizes at Catalog Editor tab.
Here a vast spreadsheet is shown. When I export this to excel, I cannot see all the options as I saw in the previous mentioned spreadsheet.
Such as Post Name has a separate column, S1, S2 and S3. When exported to excel only one of these ports are visible and thus editing a reducing tee is difficult.
There are a few more of these examples, where the editing table has more options than the exported excel sheet. Such as Thickness and Length.
Is there something I am missing or is it not possible to do such fine tuning of your catalog?
Kind regards,
Alexander
Solved by jabowabo. Go to Solution.
Use 'File', 'Export to Catalog Builder' to get the other fields into excel. After you edit, you will have to build the catalog with 'Catalog Builder' and add it back in to the original. I follow these steps:
This is the way I do it but there may be a better method.
