Hello Expert,
I am trying to build catalog for ID Pipe used in Paper and Pulp industry. When I try to import the excel file to after inputting all the parameter the validation come to about 90% and stays there for long time (4 hrs). I have to go and cancel the windows process to stop it.
Anybody else run into this problem? Any help is greatly appreciated.
Samson Thomas
Solved by samsonthomas7606. Go to Solution.
Hi Samson,
Which version of P3D are you running? 2013?
Could you outline your steps in a little more detail? You’re starting this catalog in the Spec Editor correct? Then exporting to Excel and importing back from Excel?
Also, have you checked for Content Packs for this? Don’t forget the option to “Request a Plant 3D Content Pack” there at Plant Exchange as well. http://autocad.autodesk.com/?nd=plant_content_packs
Hey Samson,
Just checking in. Have you had a chance to pursue this any further? Any progress?
If you've resolved this, please let us know how you worked it out.
Hello Martin,
Thanks for the reply. Sorry I got busy with our annual shutdown work.
Yes I was able to resolve this issue.
I was trying to create Fabricated ID pipe catalog generally used in Pulp and Paper Industry. I tried to create catalog with all the fittings and pipe defined together. Then I exported it to excel and changed OD, thickness and material spec only for pipe and then tried to import it back to catalog builder. That's when catalog builder was not responding.
I tired creating only pipe catalog (no fittings). Did exactly the same as before and imported it back and it works just fine. Then I tried elbow only and it also worked fine.
I have requested this catalog since 2011.
Thanks for you help.
Samson Thomas
Glad to hear you got it working. Thanks for letting us know how you went about it.
I got the same problem, I open the catalog pipes and fittings 2018 => then export to catalog builders => then modify to adding the materials, design, etc. => and i also delete some tab that is not necessary for my company catalog => but when I launch a catalog builder => build => build catalog => and it runs for an hours => hours => and not thing happen. I did close off and do it again. but not successfull. can you help me out.
Yes, I got the same problems, I did try to run on version 2016, 2017 and 2018. I did try differents excel files. some times it did import but not all. It's missing half of components, and some times it is jam, even I let it runs overnight. I was desperate, and now I modify directly into the original catalog. (what I did for trying: export from the catalog builder, then just modify the description, the length, the weight, I always very carefull in the excel file, not to add any column, just fill in the blank column, materials, etc. but it is not working).
