AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Catalog Builder problem
8 REPLIES 8
Message 1 of 9
agutak
1185 Views, 8 Replies
I can't see ribbon in my Catalog builder. What should I do?
I've already tried to turn it off and on. Nothing!
When I right click on top of the window, menu "show tabs" is empty.
So I can't export my template to Exel.
Can anybody help me?
Anatol D. Gutak
Tags (2)
8 REPLIES 8
Message 2 of 9
Rich.O.3d
in reply to: agutak
is the show panels empty also
if not are the panels ticked
also just to the right of the home tab (top left corner) is a little arrow...you panel might be minimized, if you hover over it, does it say show full ribbon
if you still dont have the ribbon, can you post a screenshot please
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Message 3 of 9
agutak
in reply to: Rich.O.3d
Show panels aren't empty and all are ticked.
When I hover over this arrow it asks me do I want to minimize ribbon. When I press it Catalog Builder just closes.
The same was with english and german versions
Anatol D. Gutak
Message 4 of 9
Rave.Tam
Have the same problem too. When i click Show Tabs, it give me an empty list
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
Message 5 of 9
Audun_Opdal
in reply to: agutak
I have the same problem.
Anyone have a solution for this.
Message 6 of 9
ZdenkoKozar
in reply to: agutak
It's .NET Framework 4 error. You probably have .NET framework 4.5 installed. Uninstall it and install .NET Framework 4.0. I've heard that Microsoft .NET Framework 4.5 came with betas of 2014 products. It worked for me.
Zdenko Kozar
Education and tech support manager
PRIOR inženjering d.o.o.
http://www.prior.hr
Message 7 of 9
agutak
in reply to: ZdenkoKozar
In Plant 3D 2014 it's OK
Anatol D. Gutak
Message 8 of 9
ZdenkoKozar
in reply to: agutak
Installing Showcase 2014 from Plant Design Suite 2014 installs .NET framework 4.5 which breaks Catalog Builder in 2013. Ribbon is gone again.
However, there's Catalog Builder from 2014, which works.
Zdenko
Zdenko Kozar
http://www.prior.hr
Message 9 of 9
Rave.Tam
Thanks! Unfortunately, i still need to use .NET4.5.. Have to go with 2014.
”Boost
