AutoCAD Plant 3D General DIscussion
Active Contributor
0 Kudos
Post 1 of 7
Cannot Change Size
433 Views, 6 Replies
04-14-2011 02:53 PM
In plant3d I cannot change the size of a pipe or valve etc, when I click on the item there is no drop down list in the properties dialog box for size. Please help.
Re-Installed Plant3d, problem fixed.
Valued Mentor
65 Kudos
Post 2 of 7
Re: Caanot Change Size
04-14-2011 03:15 PM in reply to: cad.westie
chaange size like this :smileywink:
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Employee
39 Kudos
Post 3 of 7
04-15-2011 09:20 AM in reply to: Rich.O.3d
Is there no size property in the Plant 3D section of the Property Palette, or is there no pull down for sizes?
Peter Quinn
Senior Product Manager
Active Contributor
0 Kudos
Post 4 of 7
Re: Cannot Change Size
04-17-2011 01:35 PM in reply to: cad.westie
Thanks for your reply. The properties pallete does have size as a property but it has no drop down list so no way of changing the size of any items, this happens on all specs even out of the box plant3d specs.
Valued Mentor
65 Kudos
Post 5 of 7
04-17-2011 04:41 PM in reply to: cad.westie
the setting for weather things are viewable or editable in the properties box are controlled in the project setup.
in the project properties box, pick: Plant 3D Class Definitions and say: P3d Line Group.
on the right hand side note the settings for nominal size - read only - visible in area view etc
I think this might be the control your after
Cheers
Richard
CAD Management 101:
Active Contributor
0 Kudos
Post 6 of 7
04-17-2011 04:58 PM in reply to: cad.westie
Thanks for the reply. Attached is a view from my project setup, nominal size is not shown as read only.
Active Contributor
0 Kudos
Post 7 of 7
05-01-2011 06:55 PM in reply to: cad.westie
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
