AutoCAD Plant 3D General DIscussion
Active Contributor
snijdam
Message 1 of 4 (400 Views)
Can't draw fittings anymore with standard spec connect error
400 Views, 3 Replies
10-11-2013 03:25 AM
Today we encountered the following issue:
I route a pipe of 2" CS300 without any problems.
When I try to route a 4" CS300 line it does not show an elbow when routing. When I click at an angle it places the minimum amount of pipe.
I tried the line to pipe function. I get two connection error messages. It places two pipes and an elbow on top of it.
I tried an other project whith the same spec it works without any problems. So the spec is good.
What could cause this problem?
Product Support
quentin.contreras
Message 2 of 4 (371 Views)
Re: Can't draw fittings anymore with standard spec connect error
10-11-2013 12:28 PM in reply to: snijdam
Did you make any changes to the CS300 spec that is in the Project you are working in? If you start a new Plant 3D drawing within that project, do you get the same issue?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Active Contributor
snijdam
Message 3 of 4 (337 Views)
10-13-2013 10:45 PM in reply to: quentin.contreras
Today I figured out what caused the problem. A colleague thicked the box for acception of imperial to metric connections for a buttweld joint.
Product Support
quentin.contreras
Message 4 of 4 (308 Views)
10-14-2013 05:25 PM in reply to: snijdam
Thank you for coming back on here to let us know what was causing your issue. Great job on finding the problem! :smileyvery-happy:
Quentin Contreras
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
