AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can not See Elbows in NavisWorks
4 REPLIES 4
batone79
1603 Views, 4 Replies
How can I do to see elbows in naviswork 2012?
Thanks.
4 REPLIES 4
thebearjed
in reply to: batone79
Go to the Options Editor and make sure your DWG loader Version matches your Autocad Version.
kudryavcevrm
in reply to: thebearjed
Plant 2013+ NavisWorks manage 2013 .I have the same problem with ebows!
thebearjed's advice does not helps (dwg loader version=2013 in settings)
Also, there's no Plant 3D specific properties in NavisWorks!
dennis
in reply to: kudryavcevrm
Has the Plant ObjectEnabler been installed?
kudryavcevrm
in reply to: dennis
Yes, I has the Plant 3d enablers 64-bit installed on that PC. May be something wrong with C++ redistributables (see http://forums.autodesk.com/t5/Autodesk-Navisworks/Elbows-and-fittings-missing-amp-Object-enabler-wil...), because this PC has many products installed (CAD's, Visual Studio's, etc...)
”Boost
