AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Can i edit a spec created in plant 3d 2012? We are using plant 3d 2014
4 REPLIES 4
jlott
456 Views, 4 Replies
We have a client supplied pipe spec and i need to add a flange to it and get and error (see attached screen shot
4 REPLIES 4
TRdesigner82
in reply to: jlott
I was getting this error too. The long descriptions didn't have styles set up for them. Try picking one of the default styles and see if that helps.
jlott
in reply to: TRdesigner82
thanks, that worked in getting flange into spec.
.......But now i cannot see that added flange in the tool palette so i can place in my model
jabowabo
in reply to: jlott
Make sure the spec you edited is in the project spec sheets folder.
TRdesigner82
in reply to: jlott
I don't use the tool palette because it takes too long to load our specs from the network. Try looking in your spec viewer and see if its there. If you do want the tool palette, make sure your plantdynamictoolpalette is set to enable.
”Boost
