is there anyway in Autocad to calculate the inches of weld for a line or a system?
Solved by Erdemlix. Go to Solution.
At the Ribbon> Home>Data Manager>Piping and Equipment>Fasteners>Buttweld
This shows every welding at the project. But there is nor lenght neither sum of the weld.
But, if you can use macros at excell, I think it is possible to determine it(Also just excell can work)
Thanks for helping.
I was hoping for some sort of automatic way that AutoCAD could do, but that seems to be a solution I can live with.
