Can CADWorx files be integrated into P3D 2015 to form a single funtioning project model? The question was posed by a potential client so I am guessing they have some existing CADWorx files that may be of some use (or not) with the new P3D work that we would be doing.
I did some testing with some CADWorx files we had and the pipe came in wireframe with no associated data. Equipment came in as a solid and I was able to add some P3D tags to the graphics
Solved by dgorsman. Go to Solution.
CADWorx 2012 and earlier shoudn't pose a problem. CADWorx 2013 and later requires an object enabler, same as if somebody was trying to view your Plant3D models without the program, or if you were XREF'ing grade models from Civil3D.
