AutoCAD Plant 3D Forum
Welcome to Autodeskā€™s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Build vent/drain assembly?
4 REPLIES 4
thebearjed
1417 Views, 4 Replies
Is it possible in Plant 3D to build an assembly for vents/drains? For example, to have an olet-nipple-valve-plug insert as 1 component but show up individually in the BOM?
4 REPLIES 4
Have you had a chance to read the help item related to assemblies in the Plant 3D help?
To create and use assemblies
http://help.autodesk.com/cloudhelp/2015/ENU/Plant3D-UserGuide/files/GUID-6670B0B6-B173-4285-AAF4-50A...
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
no sir, i didn't see that before. thank you.
patpat79
in reply to: thebearjed
Model your component assembly in plant 3d, use wblock command to save it on a folder(this will be your assembly library). Then thats it, use import block to use your assembly in the model.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
thebearjed
in reply to: patpat79
finally got around to trying this out. not ideal. have to make too many blocks for every spec and orientation, plus it does not insert on the current line number....too much work IMO.
ā€Boost
