Is it possible in Plant 3D to build an assembly for vents/drains? For example, to have an olet-nipple-valve-plug insert as 1 component but show up individually in the BOM?
Solved by quentin.contreras. Go to Solution.
Have you had a chance to read the help item related to assemblies in the Plant 3D help?
To create and use assemblies
Quentin Contreras
Technical Support Specialist
Model your component assembly in plant 3d, use wblock command to save it on a folder(this will be your assembly library). Then thats it, use import block to use your assembly in the model.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
