i have a Bug in 2014.2. If i create a new Metric Project without a template project, then i create a Pipe with the Standard Spec 16HS01.
After this i create a cylinder with ( for example. D=150mm and a height from 50mm) and create a block, After i do the connections with plantpartconvert. then i create a custom part valve with this block. Connectionend "PL" only for testing.
Now, when i drop down the valve on the pipe the message pops up (look screenshot) Both are metric. measurement=1 and measureinit=1, units on mm.
The question is, can I just plan ahead and ignore this message? or have i problems later with this ignored message?
Need fast help thx.
