AutoCAD Plant 3D Forum
Bringing Plant 3D Structure properties into Navisworks
1 REPLY 1
417 Views, 1 Reply
Using Plant 3D 2013 and have added structure to model, i have labeled the Column ID and Comments fields which will be referred to by on-site contractors when they are viewing the model through Navis. I have populated these fields but they do not come across into Navis, have switched on the convert entity handles.
Wondering is there a way to bring these across?
1 REPLY 1
Arun_Kumar_K
Navisworks supports many softwares. But it is not supporting the Plant3d software, I am wondering why?, eventhough it is the property of Autodesk. I had a similar issue with viewing the property of Pipe elevation, created a post in Navisworks forum too, but no reply from them. I had raised the query before 1.5years, no solution yet. Department of Navisworks never cares for improvement for Plant3d department in my opinion.
”Boost
