AutoCAD Plant 3D Forum
BONDSTRAND Pipes and Fittings Catalog
6 REPLIES 6
Ahmed1081975
2233 Views, 6 Replies
Dear Autodesk Supports,
Regarding your last Catalog (BONDSTRAND Pipes and Fittings Catalog) there are end connection Call KLF & KLM &
MDO..., all those connection not available in the program itself but those connection in your attachment
(DefultConnectiorsConfige.xml). in the attached file screen shot for my issue.
Please Advice
Ahmed Helal
6 REPLIES 6
in reply to: Ahmed1081975
did you follow the instructions in the readme file.
you also need to replace the DefaultConnectorsConfig.xml
if you did then it may be due to a language version (ill let one of the devs chime in if thats the case)
Venkatesan.A
Ahmed,
First you need to be aware of the connection rules defined by Bondstrand like KLF should be connected to KLM ends etc.,
KLM and KLF means Key lock male and female joints respectively, and DOM, DOF means Double O ring Male and female joints.
As rich mentioned the bondstrand content pack has the "DefaultConnectorsConfig.xml" inside which such rules from bondstrand are predefined for you to start using right away after you download this content pack.
Please follow the instruction in the readme file and you should have no problem i guess.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Ahmed1081975
you have to add also those connection in the Endcoding.xml file
For this catalog, there are some new Endtypes added as below,
DOM - Double O-ring Male
DOMK - Double O-ring Male w/key
DOF - Double O-ring Female
KLF - Key Lock Female
KLM - Key Lock Male
You can use the command “PLANTENDCODES” to add these endtypes in AutoCAD Plant3D
Venkatesan.A
Ofcourse you should, the help document link has been provided in the readme file to do that.
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
Ahmed1081975
Thanks Very much
Problem Solved
Ahmed Helal
well that was an odd thread...the question got a kudos and the highlited solution tick is located three or four posts after the initial solution!
”Boost
