Hi!
Can anyone tell me how to set the column widt in the BOM-table in the ISO-template? I am trying to set it by using the grips, it then looks fine, but when i try to save it, the column width pops back to how it was in the first place. Any ideas?
Solved by dave.wolfe. Go to Solution.
Yea, it's a bug. If you close it without using the SAVE or QSAVE commands the changes will stick.
To add to this, after changing the draw area and no draw area, just hitting the "X" to close off, and save when prompt WILL NOT save your new drawing area. it will turn it back to default again. You must use the "X-Return to project setup" icon in the ribbon for the changes to take affect.
