AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
BOM table Column Width P3D 2012
3 REPLIES 3
1043 Views, 3 Replies
Hi!
Can anyone tell me how to set the column widt in the BOM-table in the ISO-template? I am trying to set it by using the grips, it then looks fine, but when i try to save it, the column width pops back to how it was in the first place. Any ideas?
Tags (3)
3 REPLIES 3
dave.wolfe
Yea, it's a bug.  If you close it without using the SAVE or QSAVE commands the changes will stick.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/ISOGEN-settings-between-2011-and-2012/m-p/3141422#M31...
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
in reply to: dave.wolfe
Thank you!! Saved my day!
To add to this, after changing the draw area and no draw area, just hitting the "X" to close off, and save when prompt WILL NOT save your new drawing area.  it will turn it back to default again.  You must use the "X-Return to project setup" icon in the ribbon for the changes to take affect.
